LenMiddx
As Ken says, there's only the audio level meter to play with, so you'll need to experiment beforehand.
The Osmo is not very good at recoding sound as:
(a) You can't monitor it except via the level display
(b) You will not know about any extraneous noise from whatever source -- especially wind noise.
(c) There are no limiters or AGC, so if you get a sudden loud noise, your audio is going to clip.
(d) Depending on where the microphone is positioned, you may pick up the noise from the gimbal motors
(e) It's mono only
So just do your best
(Is this recording going to be just for your own interest?)
The filming itself should be OK -- but remember that every so often (9 minutes at 4K), you will lose 2 seconds of sound and vision when the Osmo closes the current file and starts a new one -- so try and stop/start every few minutes when convenient. There is, in any case, a limit of 30 minutes per 'take'.
Last week I needed good sound to go with my Osmo video ....... so I didn't record it on an Osmo.
