DJI-Ken
Flight distance : 1515312 ft
The cradle is made to hold your phone without a case unless you have one of those super slim cases.
Also, when do do figure out how to attach a lens, be careful as you are throwing the balance off on the tilt motor and if the motor gets too hot you may damage it.
Same with trying to make a larger adapter, that will severely throw off the tilt balance.
If you want to test for yourself, you can make your phone off balance and you can see how hot the roll motor gets.
The gimbal really needs to be as balanced as possible for proper stabilization and long life.
