Phantom 3 standard downgrade
769 7 2016-9-9
oomichalekoo
Poland
If i downgrade phantom 3 standatd i must calibrate imu or not?
2016-9-9
DJI Natalia
Flight distance : 318 ft
Hello oomichalekoo, it's not recommended to downgrade the firmware and it's better to calibrate IMU after upgrading.
2016-9-10
oomichalekoo
Poland
Natalia after update i have a short range when is Next update?
2016-9-10
oomichalekoo
Poland
What give IMU?
2016-9-10
DJI Natalia
oomichalekoo Posted at 2016-9-10 16:49
After you upgraded both aircraft and remote successfully, you could delete APP and install it again.
Before flight, please make sure there is no or less interference around, such as buildings, WiFi, wires or metal.
During flight, please do not fly it above your head and try to fly farther then higher, or fly to other directions, such as East firstly then West.
2016-9-10
oomichalekoo
Poland
Natalia and Next questów how change ce to fcc add 2 line end" iw reg set US and iw dev wlan 0..."
2016-9-10
DJI Natalia
oomichalekoo Posted at 2016-9-10 18:52
Hello oomichalekoo, the aircraft will adjust itself automatically from the two certifications according to your location, we could not change it manually.
2016-9-10
oomichalekoo
Poland
Why dont change in youtube is solution mod 27 phantom People try and work this
2016-9-10
