Cetaman
Flight distance : 2528264 ft
Aloha mick,
It sounds like you have said you have three pages of Flight Records. One with your name, one with the Phantom's name and one page that combines the two. If that is correct, the page that combines the two should be what you are looking for - all under one title. Sure the database will have different names in one column, but the page amounts to a "Title".
Also, if you click or double click on the Column Head, most database lists reorganize for alpha or numerical list mode using that column. The date column will list forward or backward chronologically. The name column will reorganize forward or backward with the the two names. The distance traveled column will reorganize in increasing or decreasing distance depending on how many times you click it. And on and on.
Hope this helps!
Aloha and Drone On! |
