MD_Icarus
Unfortunately, the P4 does not change channels anyway, (very seldom and when it does, it is not when the signal is low). I have been doing range/signal testing last few days and in about 60 minutes of flight time, it switched channels 3 times. But it did not switch channels when the HD signal was going to get lost. My hope was that once th esignal is almost 0, then it should switch to another channel.
But I keep it in Auto anyway.
My long term plan is to keep records of which channel(s) work best in the different areas I fly. I will then go Custom.
BTW: You will have to use Litchi if you want to see which channel the P4 is using during a flight. The Go app does not include the channel. Maybe DJI will add it soon, so we can all see it.
