dji phantom 2+ vision convert to gopro setup
6342 9 2016-9-14
omdawe
Indonesia
Hello!.. i guess my question been answered but i cant find it!..
I live in Indonesia (with little or none existing of DJI parts) and i want to upgrade my DJI Phantom 2+ to have a GoPro camera + gimble instead!..
So a mate of mine could pick up the parts in Australia for me but when i called a shop close to him, they did not know what kind of parts i needed to do this convertion!..
So here i am asking what parts and how to do this so i could tell the shop what i need!
Thanks for any advice!
2016-9-14
labroides
Flight distance : 9991457 ft
You can fit a gimble and Gopro to a P2 but the P2V+ isn't compatible with a Gopro.
2016-9-14
DJI Natalia
Flight distance : 318 ft
Hello Omdawe, Phantom 2 V+ does not support GoPro camera, that means you could not upgrade it your DJI Phantom 2+ to have a GoPro camera + gimble instead.
2016-9-14
omdawe
Indonesia
But for sure i could take off the camera thats on my DJI Phantom 2+ and put a gimble that fits a GoPro!. for sure.. with some type of FATSHARK that would broadcast the camera to me!
2016-9-14
labroides
omdawe@yahoo.co Posted at 2016-9-14 18:52
But for sure i could take off the camera thats on my DJI Phantom 2+ and put a gimble that fits a GoP ...
You would have no way to control of the Gopro or the gimbal  or view through the camera so it wouldn't be an upgrade
You need to find a straight Phantom 2 if you want to go with a Gopro but it would probably be cheaper and definitely much better to just buy a P3.
2016-9-14
omdawe
Indonesia
Ooo that sounds crap!.. But the P3 and the P4 are so limited!
Anyway thanks for all the advice !
2016-9-14
labroides
omdawe@yahoo.co Posted at 2016-9-14 20:46
P3 & P4 limited?
How?
Wait till you see how much more limited your plan would be.
2016-9-14
quanthonytrang
Flight distance : 419980 ft
Can be done.
I have a GoPro 3+ BE and a GoPro 4  BE on my P2 VISION PLUS with a zenmuse H33D. Others have modded to aftermarket gimbals and other video feeds.
Here is mine with the Hero 4 Black using the 30pin Rear Port.
This same bird has been modded with sony CCTV camera with the Samsung Gear 360 to do 360 VR flights.
Many have this mod. The hack is cheap. You just need a $10 15cm Zenmuse cable and reroute 1 cable from the wifi module.
Here is the link for more information.
http://www.rcgroups.com/forums/s ... 2213815&page=17 (Pitcher8811's comment is the how to).
2016-9-14
x2EkCkz6oYPr
Flight distance : 8215 ft
quanthonytrang Posted at 2016-9-15 07:46
Can be done.
I have a GoPro 3+ BE and a GoPro 4  BE on my P2 VISION PLUS with a zenmuse H33D. Othe ...
Hi quanthonytrang,
I am unfortunately not very fit in this kind of modding. However, if I understand the information your link leads to correctly, than there is no soldering required to get the P2 Vision+ retro fitted to Zenmuse/GoPro and get the FPV. It requires "just" to re-route some of the cables and add a $10 cable. Is my understanding correct?
BTW I can not see your pictures. Can you please re-post them. Thanks.
2016-9-20
omdawe
Indonesia
@quanthonytrang
Thanks, I will be looking in to rcgroups.com forum!.. thanks for the help!
2016-9-22
