Donnie
Flight distance : 3636782 ft
First read this link , it is my tips page : http://forum.dji.com/thread-45630-1-1.html
You need to update both the RC controllers to 1.7.40 ( THE SLAVE IS NOT UP TO DATE ) BUT ALWAYS UPDATE THE AIRCRAFT FIRST !!! YOU ARE UP TO DATE ON THE AIRCRAFT , THIS IS FOR FUTURE REFERANCE. ( I have a feeling , you did not do it this way )
I am assuming that you did the registration process first and perhaps tested the equipment before upgrading . I hope you at least registered with DJI.
1.8.1.00 is the latest update for the X3 camera and 1.9.1.30 is the latest update for the aircraft
The reason you got stuck in Transport Mode is you updated the RC transmitter before the Aircraft ( Not my first Rodeo ... ) I bet what you did was linked the slave to be the Master to get out of the transport mode. IN the future this wont happen if you ALWAYS UPDATE THE AIRCRAFT FIRST,, even if the Go app says update is available to the RC tranmitter dont do it ! Check on the Release notes if there is an update for the Aircraft as well. You lucked out having the second Transmitter or you would have had to rollback the master to the previous version .
Remeber, you can only have one Master RC Transmitter.
Update the slave remote the same way you did the master . The SLAVE IS THE ONLY DEVICE NOT UP TO DATE. THE + SIGN I EXPLAIN IN MY LINK. TO CUT TO THE CHASE ON THAT , YOU ARE OK.
Your Go App is up to date.
The moderators do a pretty good job, but you will be suprised what a few of us formum members know as well........
Good Luck and Go Slow and now read that tips page link FIRST, IT IS ONE PAGE , TAKE 5 MINUTES .
Of course you can simply wait for the moderator to help you out, I understand, up to you .
Just to confirm you have the Inspire 1 V2 with the X3 Camera and dual remotes correct ?
****NEVER UPDATE THE AIRCRAFT WITH THE TRANMITTER ON AND DONT UPDATE THE RC WITH THE AIRCRAFT ON, THIS CAN CORRUPT THE VIDEO TRANSMISSION MODULE...................TRUST ME ON THIS
Dont link the Slave to the Aircraft either ( I have seen this mistake also ) the slave communicates with the master and NOT the aircraft, all you will be doing is "finding" the Master RC with the slave RC. This is accomplished on the Remote control settings of the go app. Just make sure both RC transmitters are on the same version ( ie ;1.7.40 ) Make sure the Master indeed has control of the aircraft and then " Find " the master via the slave remote.( both must be on and one which contorls the aircraft is Master and the other would be "slave ) There are videos on dji and also you tube, just wanted to mention this so you did not try to 'bind' both transmitters to the aircraft
have fun and good luck .
donnie
