I was curious if there was a way to lock the gimbal direction in the app instead of the standard method of holding the trigger down?
The reason im asking is I need to do a shot with the extension rod but need the gimbal direction to be locked... i looked in the manual and tried to dig through the app but I think Im overlooking something
The only way I've seen is when shooting a Timelapse, there's an option for "tripod mode". I know this isn't a solution for normal video but it shows that the gimbal can be locked. Hopefully DJI will add the ability for other camera modes as well.
Hi, press the gimbal button on the right side when you enter the Osmo view, in it it has an option says "Orientation lock" , click it , then it will lock the orientation.
