quanthonytrang
Flight distance : 419980 ft
There are 3 sets of cables that come from the Phantom to the gimbal board. The 2 wide cables acts like a bridge to power up the gimbal. Unplug these 2 and inspect and make sure they are not damaged. Reseat them firmly and try again. If this does not work, then chances that the wifi module is dead or not sending power to the gimbal.
To see if there is power to the wifi module, you will need to open up the phantom. With the newer revised modules, they are perforated with holes. You can actually see if there is power by looking through the holes to see if the LEDS flash green or red.
