on My Phantom 3 standard stream is OK. I can see on my phone everything, it means WiFi module is OK ,but cant take pictures or filming. The big button on right side of APP is black.
Hello kulovec, you use the original SD card, right? and what mobile device you are using? you could record or not? Please post a screenshot here, thanks.
Mine did the same. Just remove the card, clean the contacts on it with a q-tip and a tiny bit of alcohol. Make sure it is dry, then re-insert and try again.
