The first photo is overexposed
1005 8 2016-9-20
Drone Cuiabá
Flight distance : 13272894 ft
Brazil
Every time photo shot in D-Log on camera X5, the first is overexposed.
I use the S mode and the first picture is taken with the longest exposure time that the second and the others. Back to record a video and when I take another picture is the first new overexposed.
See the photos I sent. The difference between them is 2 seconds. The first opening is 1/40 sec and second 1/80 sec.
It happens to anyone else?
1/40 sec
1/40 sec
1/80 sec
1/80 sec
1/80 sec
1/80 sec
1/200 sec
1/200 sec
2016-9-20
DJI-Jamie
Flight distance : 112405 ft
Are you noticing duplicate pictures with ones being under exposed as well? You do not have HDR enabled, correct?
2016-9-20
markaguille
Flight distance : 2031818 ft
Jersey
Does it do the same in M mode?
2016-9-20
Drone Cuiabá
Brazil
DJI-Jamie Posted at 2016-9-21 06:16
Are you noticing duplicate pictures with ones being under exposed as well? You do not have HDR enabl ...
HDR disabled
2016-9-22
Drone Cuiabá
Brazil
markaguille Posted at 2016-9-21 11:12
I never tested in manual mode. I believe that this does not happen in manual mode. Apparently is a problem in relation to automatic mode that controls the exposure time.
The funny thing is that only happens after I record a video.
2016-9-22
DJI-Jamie
Drone Cuiabá Posted at 2016-9-22 23:28
I never tested in manual mode. I believe that this does not happen in manual mode. Apparently is a ...
That does seem odd. Have you already tried resetting the camera settings or delete/reinstall the Go app? Does this only happen while in D-Log, or does it happen on other color settings as well?
2016-9-22
markaguille
Jersey
Drone Cuiabá Posted at 2016-9-22 16:28
The camera isn't in AEB mode?
2016-9-25
Drone Cuiabá
Brazil
markaguille Posted at 2016-9-25 19:38
no, is normal mode
2016-10-15
Mike-the-cat
Flight distance : 22488593 ft
This is a known bug when you are shooting video, stop and then take a still. The first still in that sequence is often a white out. I'm surprised nobody has complained of this earlier. Its been with the Inspire since I started flying and it doesn't matter which camera you are using.
I typically discard that first still and expect it to be a throwaway.
No problem if you start with the still setting and shoot.
2016-10-16
