Firme ware udate with Z3
1337 6 2016-9-21
ukea
I got a message from the DJI Go app   AIRCRAFT update required, ,The  Inspire1 has a z3 camera attached, I have  downloaded the new firmware, unzipped to sd card placed in the INSPIRE1 Z3 camera,, turn on and,,,,, the INSOIRE wont update,, I tried 3 times, the Inspire will not update,,, mmm I thought,,, take Z3 camera off and replace with X3, AIRCRAFT is UPDATING,,,,whats that all about????????????
Here is the txt after using the x3 camera to update the Insoire1 firmware..
Result: Success.
========== 2015.08.26 18:55:53 =====================
Packet: WM610_FW_V01.03.00.00.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.08.26 18:57:31 =====================
Upgrading ...
========== 2014.01.01 00:00:04 remo-con disconnect======
Upgrading ...
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
========== 2015.08.26 19:19:37 =====================
Result: Abort.
========== 2015.09.16 20:21:15 =====================
Packet: WM610_FW_V01.04.00.10.bin
Upgrading ...
Result: Success.
========== 2015.09.16 20:30:10 =====================
Result: Abort.
========== 2015.09.17 13:43:03 =====================
Upgrading ...
Result: Success.
========== 2015.09.19 18:15:37 =====================
Result: Abort.
========== 2014.01.01 00:00:03 remo-con disconnect======
Result: Abort.
========== 2015.09.19 18:25:32 =====================
Result: Abort.
========== 2015.09.28 12:46:43 =====================
Upgrading ...
Result: Success.
========== 2015.09.28 12:48:47 =====================
Result: Abort.
========== 2015.09.28 13:09:54 =====================
Upgrading ...
Result: Success.
========== 2015.09.28 13:11:56 =====================
Result: Abort.
========== 2015.09.28 13:31:20 =====================
Result: Abort.
========== 2015.09.28 13:59:00 =====================
Upgrading ...
Result: Success.
========== 2015.09.28 14:00:55 =====================
Result: Abort.
Packet: WM610_FW_V01.05.00.30.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:06 remo-con disconnect======
Upgrading ...
Result: Success.
========== 2015.12.17 13:20:55 =====================
Upgrading ...
Result: Success.
========== 2015.12.17 13:23:24 =====================
Upgrading ...
Result: Success.
========== 2015.12.17 13:25:55 =====================
Upgrading ...
Result: Success.
Packet: WM610_FW_V01.06.00.40.bin
Upgrading ...
Result: Success.
========== 2016.02.23 13:38:14 =====================
Upgrading ...
Result: Success.
Packet: WM610_FW_V01.09.01.30.bin
Upgrading ...
Result: Success.
2016-9-21
DJI Natalia
Flight distance : 318 ft
Hello sir, please make sure you downloaded the corresponding Zenmuse Z3 Preinstall Firmware. You could double check it here: http://www.dji.com/zenmuse-z3/info#downloads
Then please upgrade it with Z3 camera again.
2016-9-21
BIGDZ
Flight distance : 10255860 ft
DJI Natalia Posted at 2016-9-21 17:34
Hello sir, please make sure you downloaded the corresponding Zenmuse Z3 Preinstall Firmware. You cou ...
Would this fix the break up and lagging issues? I have the most recent update for my I1 but it wasn't update with this fw
2016-9-21
Donnie
Flight distance : 3636782 ft
BIGDZ Posted at 2016-9-21 08:51
Would this fix the break up and lagging issues? I have the most recent update for my I1 but it was ...
This is for the Z3 and Not the X3  , Just want to make sure you knew they were on different cameras.
donnie
2016-9-21
BIGDZ
Donnie Posted at 2016-9-21 06:53
This is for the Z3 and Not the X3  , Just want to make sure you knew they were on different camera ...
Yeah,  I know...I have a paper weight Z3 was hoping this was a fix
2016-9-21
Donnie
BIGDZ Posted at 2016-9-21 10:27
Ok, sorry , I thought you might have been inquiring about the X3.....( similar challenges )
My apoolgies, good luck getting it resolved.  I think If I just bought it I would send it back if there is trouble already.
donnie
2016-9-21
BIGDZ
Donnie Posted at 2016-9-21 08:32
My ap ...
Unfortunately, that time has come and gone...
2016-9-21
