MD_Icarus
I am not trying to "be the rain in your parade", BUT
Even though I have a lot of RF Design experience with antennas, one thing I believe is not to try to re-invent if there is a proven design out there. There are so many factors to consider like SWR, gain mismatch, relative antenna placement, Polarization characteristics (V, VH, degrees of offset,...........) Unless you have very expensive test equipment, (scalar network analyzer, reference antennas, shielded test room...) there is no way of proving such a design.
But let's not forget another important aspect:
Unless you boost the P4 antennas too, then it won't matter what you do on the ground; You will lose signal from the P4 anyway.
Even if you use the following set up, which I called previously the ULTIMATE BOOSTER!!!
Ultimate Mod
