Kneepuck
Flight distance : 275105 ft
Most often with the standard, the video signal is lost first, but not always. But, if the control signal is truly lost, then there should be a 3 second delay and then rth will activate, and it will rth, provided the rth point is properly set, the rth mode is properly set and you are more than 20 meters from the home point. If you are less than 20 meters, it will land in place. If you are below rth set height, it will increase altitude to that height and then rth. If you are above rth set height, it will maintain whatever height is at and rth, after a short delay. If it is about to automatically rth due to control signal lost, and you move the sticks during the 3 second delay time and it receives that command, it will cancel the rth automatically, because it recognizes the signal is restored. This can happen with the Standard . It does happen with the Standard. If rth begins, after the 3 second delay for automatic rth due to signal loss, it will begin to return to home. As long as the signal is truly lost, you will not be able to cancel rth or to direct the phantom in any way. Becausee the signal is lost. Once you are back in range, signal reconnected, then you can cancel rth or just guide the aircraft to avoid obstacles while it continues to rth. Once it begins signal lost rth, or any automatic rth mode for that matter, you will have to manually cancel rth to turn it off. The only time it will automatically cancel automatic rth is, as I said, if it recovers the control signal in the 3 second pause between signal loss and actually beginning to move to rth. Rth for critical battery is slightly different of course. All these things are dependent on several variables like rf interfence from nearby transmitters, sunspots magnetic fields etc. Those parameters are fairly constitant and will be known to the experienced operator. Anything other than those behaviours are 1 of 2 things. A binary set solution.
A) Operator error
B) broken hardware.
99 percent of the time, the reason is A.
