mjlstudios
Flight distance : 1540131 ft
There might be times when you need to hand catch! If the ground is uneven, you should hand catch, if the wind picks up during flight, you need to hand catch, if at the beach, you need to hand catch, if you are on the water, you need to hand catch, if a crowd gathers around you with small children, you need to hand catch. Loose sand and dirt will kick up as your P3 nears the ground. Wind will topple over the P3 as it touches the ground, obstructing the motors and being recorded as a crash voiding your warranty. A crowd will always gather around me when I fly. You can inform adults to back away, but they tend to forget they have small children who want so much to try to catch it themselves. You have to be very careful when catching your P3. It will bite! you will bleed! You may loose a body part! |
