Do power lines and such cause compass errors?
4185 12 2016-9-21
Kwaka Pants
Just wondering, as I tend to avoid them like the plague, but do high voltage power lines cause problems with either the compass, or other systems on a phantom? Seen plenty of video where people are flying in relatively close proximity to them with no apparent issues, but it seems if I go anywhere near I seem to get connection or compass errors.
Discuss.
2016-9-21
Tanel
Flight distance : 291056 ft
Sweden
Well yes and no...
I got a lot of these errors with my old compass module.
Then again i got them randomly everywhere...
I have since replaced the compass module and i can go quite near to the high voltage power lines without any errors...
Not that you should go near them anyway lol...
2016-9-21
Kwaka Pants
No lol, but I'm scared of going within 100m of the bloody things. I do seem to have had a lot of compass issues, my p3s is nearly new, but faulty ones not unheard of.
Did they upgrade them at some point? Rather than send mine in for repair, if it is a bit faulty, I'd rather just buy one and fit it myself if it's easy, as they don't seem expensive?
2016-9-21
Matt-and-Riley
Flight distance : 324442 ft
Depends what type, I found this quite interesting
http://www.emfs.info/sources/overhead/
Those big 400kv ones I stay well away from, smaller ones I keep 30m from, but in the UK you'll find that most are actually telephone cables not power.
2016-9-21
Kwaka Pants
Yeah, I don't worry about the phone lines, obviously keep well away from the pylons though. Just the triple type high voltage ones have given me bother when within a stones throw. Was 40m above some once and was getting compass errors. Had put a magnetometer app on the nexus tablet, but that's gone and awaiting a new nvidia shield coming, then will do some investigation!
2016-9-21
Adam Flurk
Flight distance : 425466 ft
I have had instances with no issues and other times I've had problems. The first time I ever tried out the Point-Of-Interest feature I was quite nervous because the front of the house was littered by cables / wires... but didn't have any issues that time.
Before I had my P3P I was with a friend who was flying an AR Drone that seemed to drift towards some cell towers... Total fly away in that case but not DJI.
Look at the wires:
2016-9-21
endotherm
Flight distance : 503241 ft
Matt-and-Riley Posted at 2016-9-22 08:48
That graph may look scary, but does anyone have any idea what 6 microTeslas will actually do to the compass?  Probably not a lot unless you are within a foot or so, in which case you have other bigger problems.
2016-9-21
Kwaka Pants
Seems I'm cacking myself for no reason then lol, good vid!
2016-9-22
Matt-and-Riley
Kwaka Pants Posted at 2016-9-22 09:00
But it is considered to be a 'structure' not under your control - so 50m to stay legal I guess, wouldn't want you breaking any rules
2016-9-22
Murilo Carmello
Flight distance : 1562549 ft
I avoid flying close. But once time, I almost hit a power line and I had no interference, I got very close to it
I have seen many videos of Phantom having interference from cell towers ( some even falling), but I never saw a video of power lines interference
2016-9-22
flyfishnevada
The line near my house don't seem to pose a problem.  However, I went to mine nearby that's mostly abandoned but has active power lines going to it, probably so someone can work the tailing piles or something.  My P3S went crazy.  I couldn't barely control it well enough to get it back.  But those lines were exposed...no insulation or shielding.  Maybe that was the problem.  No other structures, trees or obstructions nearby.  Just sagebrush and those lines.  Once I got it home, the drone flew normally.
So, my answer would be use caution.
2016-9-22
Kwaka Pants
Always do, overly cautious, hence my post inquiring on here.
Did have 2 more flights tonight, both with the p3 switching in and out of atti mode. Was over a valley I couldn't see into, but at over 100m altitude no idea why anything should cause probems up there. Unless it was low satellite coverage, will have to check my logs.
2016-9-22
Aardvark
Flight distance : 384432 ft
flyfishnevada Posted at 2016-9-22 17:40
The line near my house don't seem to pose a problem.  However, I went to mine nearby that's mostly a ...
"no insulation or shielding.  Maybe that was the problem.  "
Any wire carrying a current will generate a magnetic field, which depending upon its strength and distance from quad, might affect the compass. Insulation would have no effect on this.
And then there's the electric field generated, I like this as an example:-
2016-9-22
