Phantom 3 profesional dont flight straight
walper
Flight distance : 1477572 ft
Bosnia and Herzegovina
hello
plz can someone help me
my drone do not fly straight , i try everythin , umi calibration , compas calibration , controler calibration , everything ,  i bought drone 6 month ago , all time i think thet is wind issue, "finger" issue , but its not , I fought this period to drive good , but this issue make me realy hard to drive correctly .
Becose of this issue i crash my drone few times , luckily with out any DMG . where i can send my flight record , to show you what I'm saying , plz help me and give some advice
2016-9-21
Hi walper , could you please sync your flight records and provide me with the APP email account ?
I'll help to check your flight records.
Please see the below video tutorial to sync the flight records.
2016-9-22
walper
yes i allready did
look last 4 or 5 flight records , i do it for test
2016-9-22
I have checked your flight records, but the latest flight record is on 2016/03/05.
Please make sure sync the flight records successfully.
2016-9-22
walper
plz can you check now
2016-9-22
roymoon
Flight distance : 143901 ft
Mine doesn't fly straight either.
I'm suspecting the camera is cockeyed.
No crashes either.
2016-9-22
DJI-Ken
Flight distance : 1515312 ft
walper Posted at 2016-9-22 17:30
I looked at a few of your flights and see when the aircraft went left or right a tab that the stick input was also used so that means you were moving it.
I do see the last flight on your straight line out I see it shifted a tad. Can you try a compass calibration again and make sure no around including your phone/keys and leave the RC on the ground about 10ft away from you. Then see what the compass mod values are (should be between 1,000-2,000)
Main Controller Settings, Advanced Settings, sensors.
Do that then lets see if it still does it.
2016-9-22
DJI-Ken
roymoon Posted at 2016-9-22 22:56
No crashes either.
You can play back the flight record and see if the aircraft is going in a straight line, if it is then maybe your camera is not pointing exactly straight.
Have you tried standing behind it and heading straight out and looking at the aircraft and not the screen?
2016-9-22
