New intelligent battery
839 7 2016-9-22
joshuanicholas1
Hi all,
I just saw on the DJI shop that there's a intelligent battary(high capacity) , does anyone know how much longer this battary last compared to the old one?
Thanks!
2016-9-22
That depends on which camera model you are using.
If you are using an X3 camera, the OSMO's battery life will last for 96 min under ideal conditions.
2016-9-22
joshuanicholas1
So only about 6 min extra of battery life? The original battary could last up to 90 min after the update. And yes I am using the X3 camera
2016-9-22
joshuanicholas1 Posted at 2016-9-23 15:15
So only about 6 min extra of battery life? The original battary could last up to 90 min after the up ...
Normally , the original battery's life will last for 68 min under ideal conditions.
And it is related to the way you use it and the environment.
2016-9-23
Bakafish
Flight distance : 795400 ft
Malaysia
The osmo battery that has this little ribbon just teared apart after being used few times. It's very hard for me to get the battery out from the battery compartment...
What can I do now?
2016-9-23
DJI-Thor
Flight distance : 13602 ft
Hi, it's 980mAh vs. 1125mAh, the battery life is roughly proportional.
2016-9-23
joshuanicholas1
Thank you for the reply everyone, guess I can save a few dollars on something else then !
2016-9-23
nigelbrinkmann
Flight distance : 586391 ft
Bakafish Posted at 2016-9-23 16:42
The osmo battery that has this little ribbon just teared apart after being used few times. It's very ...
ha ha buy a new battery!, just kidding, maybe use a drop or two of super glue to stick the broken piece back onto the little bit that's still on the battery....maybe?
2016-9-23
