iOSD MARK II end DJI AVL58
Vertoliot
Ukraine
Hello everybody! I have a problem: S900 with Zenmuse Z15-BMPCC video is transmitted through iOSD MARK II end DJI AVL58, video screen clear, but the information OSD - are white streaks and shakes. Prompt with this is that it can be done?
In principle, the data can be seen but annoying ....
Thank you!
2016-9-23
DJI-Jamie
Flight distance : 112405 ft
Could you provide a picture or a small video of the issue? Are all the components up to date with the latest firmware?
2016-9-23
Vertoliot
Ukraine
Thank you responded. So look on the ground, in the air are becoming more bandwidth and options on the screen almost invisible.
2016-9-24
vladimir57
It worked fine before? On your model is set one transmitter for video? Please remove the "PMU" by "Mark II" greater distance. Check, and even better - to replace the antenna on the transmitter. It is possible that there is a reliable contact in its socket.
2016-9-24
DJI-Jamie
Vertoliot Posted at 2016-9-24 17:44
Thank you responded. So look on the ground, in the air are becoming more bandwidth and options on th ...
Try vladimir57's suggestion. In addition, have you tried changing the channels on your AVL58?
2016-9-24
Vertoliot
Ukraine
Thanks for the tips! Channels changed. So it was in the previous transmitter, AVL58 delivered recently. One set for video transmitter. Antenna will try to change.
2016-9-24
DJI-Jamie
Vertoliot Posted at 2016-9-25 05:34
Thanks for the tips! Channels changed. So it was in the previous transmitter, AVL58 delivered recent ...
Please keep us posted.
2016-9-26
vladimir57
A similar problem may arise due to too thin wire "ground" or (-) between the camera and the input module Mark 2. Try this compound is a larger wire diameter. She disappeared if the "ripples" on the screen?
2016-10-8
Vertoliot
Ukraine
Replacing the antenna did not help. Try replacing the cable. Thank you.
2016-10-11
vladimir57
Make a temporary connection of the wire. Connect the transmitter "Earth" with "earth" Gimbal at the entry point into your camera.
If this does not help, connect the "Earth" Mark 2 and "Earth" AVL-58 single wire.
Try to use a shielded cable for the video signal.
2016-10-21
