Spherical panorama 360° not 180 with Osmo+
3285 20 2016-9-26
d.tomasi
Flight distance : 15968 ft
Brazil
I saw the option to make half sphere, can I make a complete sphere panorama?
2016-9-26
hallmark007
Flight distance : 9827923 ft
You can if you have an osmo if it's an osmo Mobile I'm afraid not
2016-9-26
hallmark007
Sorry you can also do 360x180 with osmo+ but you will have to use third party app litchi or dronepan
2016-9-26
dennish
hallmark007 Posted at 2016-9-26 11:08
Neither of which (Litchi or Dronepan) currently support the OSMO+ but is planned.
2016-9-26
hallmark007
dennish Posted at 2016-9-26 19:51
Both support osmo, I use litchi osmo app and have done many 360x180 it's called litchi for osmo..
2016-9-26
dennish
hallmark007 Posted at 2016-9-26 14:18
Both support osmo, I use litchi osmo app and have done many 360x180 it's called litchi for osmo.. ...
I was referring to the OSMO+ - neither app works at this time  Litchi for OSMO nor Dronepan.  I contacted both vendors - litchi said plans to support in the future.  The apps do not display the image nor take a picture with the OSMO+.
2016-9-26
hallmark007
dennish Posted at 2016-9-26 22:27
I was referring to the OSMO+ - neither app works at this time  Litchi for OSMO nor Dronepan.  I con ...
Too many osmos out there really think this would be an easy softwear upgrade for dji go app but many have been asking for almost a year and no sign.. I think it more likely litchi will sort it , and then dji won't bother,that seems the way things work at dji..
2016-9-26
d.tomasi
Brazil
I have an Osmo+ sorry, forgot to mention!
2016-9-27
dennish
Downloaded the Litchi for OSMO app that says now supports OSMO+  anyone have any luck?  Still not working for me but only tried twice tonight.  Let me know if you had any luck, I am going to reset the OSMO yet again tomorrow and see how it goes!
2016-10-5
d.tomasi
Brazil
Hey!!!! Litchi does work like a charm on my osmo+!!!
Thank you!!!
Flawless!
2016-10-7
dennish
d.tomasi Posted at 2016-10-8 03:16
Thank you!!!
Flawless!
What settings are you using in the app and what to stitch?  OSMO and App work fine - I am having issues with stitching.
2016-10-7
d.tomasi
Brazil
I did with the default setting, with 32 pictures I think!
stitched on autopano!
just a small glitch... on the stitch
2016-10-7
cloudsearcher
d.tomasi Posted at 2016-10-7 22:00
just a small glitch. ...
did you do the pano outdoor or indoor? Autopano and PTGui have problems with the stitching when I make panoramas indoors.
2016-10-14
d.tomasi
Brazil
Indoor, I will try outdoors!
Thank you for the tip!
2016-10-14
dennish
d.tomasi Posted at 2016-10-8 04:00
What photo ratio you use - 4:3 or 16:9?  I still can't get a proper stitching using either.  Just curious, thanks!
2016-10-15
d.tomasi
Brazil
Its 4:3 but I think is indifferent!
what seetings at your autopano?
Mine is: F: 22mm
Look if your lenses is set to normal!
2016-10-16
MWitarsa
Flight distance : 2058179 ft
Brazil
Have you had sucess shooting manually the ground to complete “nadir” and hide the tripod (or complete the missing spot) after shooting with Osmo+ and Litchi app?
I’m having some problems stitching on autopano. I’m not sure if I took the picture in a wrong way, or it’s a configuration inside Autopano that should be done.
2018-3-7
Mexikiwi-Dev
hallmark007 Posted at 2016-9-26 13:18
Hi there,  what is the stitching software you are using, I'm having difficulty stitching with autopano, I always get overlapping, thanks in advance for your help
Regards
Alex
2018-10-10
chiplifter
Flight distance : 745180 ft
d.tomasi Posted at 2016-10-7 11:16
Thank you!!!
Flawless!
Is that Litchi version on android or iOS. I purchased it for android, but crashes almost every time (osmo+)
2018-10-10
Mexikiwi-Dev
chiplifter Posted at 2018-10-10 11:49
I've used Litchi on both Android and iOS and worked well on both
2018-10-10
chiplifter
Mexikiwi-Dev Posted at 2018-10-10 12:38
Litchi for drones works fine on both ipad mini wih my Mavic, but Litchi for Osmo crashes. Will try it on another phone.
2018-10-11
