NAZA M2 UPDATE FAILS 4.06 ( BRICK )
starkovss
Flight distance : 867526 ft
Hi support,I have Naza M2 controller.
Today I connected it to PC and Naza Assistant told me that update available 4.06 ( I had 4.02 ).
I disconnect all motos and started Update Process.
After around 1 minute I got red messages that update Fails.
After LED module is not working ( not blinking at all ).
I cannot connect FC any more.
I tried to HARD reset :
1) connected F1 and F2 ( bridge with 3 pin connector. I tryied 3 to 3 and 1 to 1 (bottom pins only) )
2) power up
3) nothing happens ( LED still not blinking at all ), no connection to PC
4) remove Bridge from F1-F2 , power up. Nothing.
How to back it to live ? How regular official system update can Brick the device?
Please give me instruction what should I do now to make it live.
I payed around 400 CAD dollars for this device.
Thanks you.
2016-9-26
DJI-Jamie
Flight distance : 112405 ft
"Bricking" the device is not common. To clarify, the USB port no longer connects to the computer? If you are unable to connect the unit to the computer in order to reattempt the firmware update, then your best course of action would be to contact support.us@dji.com for a potential repair service.
2016-9-27
