Geebax
It would seem from your questions that you have not read the manual or studied any of the posts here, because you are asking questions that are answered in the manual and are discussed regularly on this forum.
In answer to your questions, distance when flying across town will be limited by the amount of radio interference in your area, urban areas are full of competing signal sources.
Calibration. Yes, you most certainly do not try to calibrate near any metal, concrete or such. It is VITALLY important not to try and calibrate where there is any metal around you. You need to go out in a field somewhere to perform the compass calibration.
And yes, you can switch to manual or ATTI mode at any time diring flight, but if you do you better know how to fly manually or you may very easily crah your aircraft. Manualy control is something that needs to be practised in a safe, clear area.
