Possible to connect Z15-5D (not III HD) to Lightbridge 2?
1306 4 2016-9-28
damiangarcia
Is it possible to connect the original Zenmuse Z15-5D gimbal (note: not the newer III HD version) to the Lightbridge 2 system?
Reading the Lightbrdige 2 manual, there is a cable that connects this system to the G7 port on the Z15-5D III HD, which the original version does not have.
Is there a work around here?  Or is the original Z15-5D incompatible with Lightbrdige 2?
Something that I have thought of doing is to replace the GCU in the Z15-5D with the one that comes with the Z15-5D III HD.  Again, is this possible?
Would appreciate any inputs/thoughts on the matter as I am somewhat stuck.
Many thanks.
2016-9-28
DJI-Jamie
Flight distance : 112405 ft
The original 5D is incompatible with Lightbridge 2, as it is not considered to be a HD gimbal.
2016-9-28
jw.eaglem
How about the Z-15 N7 for the Sony NEX-7 camera?  Is this gimbal compatible?
2016-9-28
damiangarcia
DJI-Jamie Posted at 2016-9-28 14:18
Jamie, thanks for confirming my (worst) fears.  About to send it back to the company from which I purchased it and get the HD version.
Thanks again.
2016-9-29
DJI-Jamie
damiangarcia Posted at 2016-9-29 17:43
Jamie, thanks for confirming my (worst) fears.  About to send it back to the company from which I  ...
You're welcome, at least you're able to get it addresses as quickly as possible.
2016-9-29
