Nvidia Sheild Saves wrong Location on
1281 15 2016-9-29
thegaz99
Flight distance : 2289144 ft
Hi all! Just started using a Nvidia Sheild K1. Very happy with it apart from one issue (so far).
When I look at flight logs it saves location as a suburb 3 miles away? Even though the map is correctly showing where I've flown. I have flown at a different spot and the suburb was correct for that flight. I seems just this one area, which is my main flying spot is coming up wrong suburb. I tried my iphone at this spot and it saved the correct suburb name. Any idea why this happening? Anybody else had a similar issue? I have installed a GPS app and it works fine and showing exactly where I am and picking up a lot of satellites.
Any help would be great as it is pretty annoying more than anything.
Thanks
2016-9-29
labroides
Flight distance : 9991457 ft
What exactly is the problem.
Can you explain it differently?
Are you saying that the mapped track is correct (as it should be) but the flight record has a different name for the location?
If that is the issue, it's got nothing to do with the tablet and will be the way Google Maps labels general areas
2016-9-29
goldfinv
Flight distance : 506181 ft
Nigeria
Try changing the location settings on the shield to gps only mode and try again.
2016-9-30
thegaz99
labroides@yahoo Posted at 2016-9-30 17:45
Are you saying that the mapped track is ...
Yes just wrong name. But name its showing is miles away. I could understand next suburb over but not three?
2016-9-30
thegaz99
goldfinv Posted at 2016-9-30 18:13
Thanks gold. Going out for a hoon shortly. Will give it a go. Cheers
2016-9-30
labroides
thegaz99 Posted at 2016-9-30 16:39
It will be a Google maps issue - nothing to do with your Phantom of the tablet.
It's just the way they name their map sheets - not intended to be a precise location.
2016-9-30
thegaz99
Hey set to gps only but didn't work. Same problem. Shows Flight Record as suburb 3 miles away. Any more ideas? Thanks
2016-9-30
thegaz99
labroides@yahoo Posted at 2016-9-30 19:09
It's just the way  ...
My iphone names the location correctly though?
2016-9-30
labroides
thegaz99 Posted at 2016-9-30 17:54
Yes ... and your iPhone app doesn't use Google Maps.
It's got nothing to do with your location.
It's all about the name Google Earth gives that map sheet and it will contain several suburbs, only on of which will be in the title.
2016-9-30
thegaz99
labroides@yahoo Posted at 2016-9-30 20:55
It' ...
Well if shield and iphone are both using GPS why are suburbs different names then?
2016-9-30
Geebax
thegaz99 Posted at 2016-10-1 09:42
Apple and Android use different map suppliers.
2016-9-30
labroides
thegaz99 Posted at 2016-10-1 07:42
Your GPS gives latitude and longitude ... but it has nothing to do with maps or suburb names.
2016-9-30
Cetaman
Flight distance : 2528264 ft
thegaz99 Posted at 2016-9-30 13:42
Aloha gaz,
     This is not as obvious a question as it may seem, but do you have locations enabled in the pull-down status tab.  Sometimes, people go straight into settings and make all the modifications without ever turning on locations.  It will also ask you if you want locations active in DJI GO.
     If you do not have locations enabled, Google will try to use other resources to try to locate your position.
     But, most likely the problem is as described by Geebax.
Aloha and Drone On!
2016-9-30
thegaz99
Cetaman Posted at 2016-10-1 15:33
Aloha gaz,
     This is not as obvious a question as it may seem, but do you have locations enabl ...
Thanks bro I will check that shortly.
2016-9-30
labroides
Aloha gaz,
It has nothing to do with his tablet or the app.
It's just the way Google Maps name their map sheets.
Nothing to worry about at all.
2016-9-30
Cetaman
thegaz99 Posted at 2016-9-30 21:59
Aloha gaz,
     Do be prepared to reconcile the problem as labroides also notes.  Nothing to worry about.
Aloha and Drone On!
2016-10-1
