Can I fly with Mavic batteries
31484 6 2016-10-1
jonnyvermont
Flight distance : 73291 ft
Mavic  Intelligent Flight Battery is rated at (3,830mAh/11.4V).
What I know is that:
The quantity permitted is based on watt-hours (Wh). Wh establishes the lithium content by multiplying voltage with the ampere-hours (Ah). For example, 14.40V x 5Ah battery = 72Wh.
I will be traveling overseas in november flying into Prague and leaving Frankfort to the US.  Does anyone know if these batteries will be allowed and is there someting I can print to prove that they can fly?
Thanks!
2016-10-1
Fulgerite
The official DJI specifications say the battery is rated at 43.6 Wh...  That should be Airline OK.
The big question is:  Are DJI batteries UN 38.3 approved?
Unless it has a UN 38.3 approval... The Airlines can reject it.
2016-10-1
terrylewis
Flight distance : 3517287 ft
Ditto Fulgerite ->
From the MAVIC specs, the Intelligent light Battery has 43.6Wh of energy each.
For US regulations, the FAA allows passengers to carry-on any number of lipo batteries under 100Wh. They must NOT be placed into checked luggage!
So you can carry-on as many MAVIC batteries as desired. If you're flying with the Inspire TB48 which is 129.96 Wh, you can only carry-on two spares.
You may download and reference this FAA document -> http://www.faa.gov/about/office_org/headquarters_offices/ash/ash_programs/hazmat/passenger_info/media/airline_passengers_and_batteries.pdf
FAA Pack Safe -> http://www.faa.gov/about/initiatives/hazmat_safety/more_info/?hazmat=7
There are similar documents available from the US Dept of Transportation -> http://phmsa.dot.gov/safetravel/batteries
UN Transportation Standards -> http://www.phmsa.dot.gov/hazmat/regs/sp-a/approvals/un-3rd-party
Safe travels...
2016-10-1
Fulgerite
terrylewis Posted at 2016-10-1 14:34
Ditto Fulgerite ->
Actually you completely glossed over UN 38.3 which is the only pertinent standard in effect.
http://www.phmsa.dot.gov/staticf ... ry_Requirements.pdf
And yes...  Anything under 50 WH should be fine for most international flights as long as it meets UN 38.3 standards.
2016-10-1
jonnyvermont
Thank you all!
2016-10-2
VECTOR 4
Can you charge a drone battery with a solar panel
2017-4-23
boblegogamerYT
Flight distance : 916444 ft
VECTOR 4 Posted at 2017-4-23 15:29
yes you can
2021-4-8
