Camera roller dial also a switch?
627 4 2016-10-4
MicroFPV
On the P4 controller... My buddy was asking me what the camera roller dial does when you press it.  I could not answer because I did not know.  You can feel that it is a push switch though.  Does this dial have any function other than exposure?
2016-10-4
Aardvark
Flight distance : 384432 ft
If I remember right it switches the function from EV to shutter speed control.
2016-10-4
MicroFPV
Ok thanks.  I had looked a couple of times and never found anything on it.
2016-10-4
poppylfh-sp
Flight distance : 3902884 ft
While holding the C2 switch on bottom of the controller the "roller dial" can be used to tilt the gimbal horizon back to level if it's not level
2016-10-4
Aardvark
poppylfh-sp Posted at 2016-10-4 17:05
While holding the C2 switch on bottom of the controller the "roller dial" can be used to tilt the gi ...
Unless you happen to be on latest DJI build, at present it does not seem to function for gimbal tilt adjustment on DJI Go 3.0.0 for IOS.
2016-10-4
