Hello,
I would like to build a non-aerial remote camera, preferably based on something like the OSMO+ camera. The challenge is to make the gimbal work without the handle with a "compatible" DJI GCU. "Compatible" is in quotes for obvious reasons as I haven't found a company sanctioned solution for this.
The applications are numerous. For example, imagine a camera installed inside the cokpit of a motor vehcicle that you can control from a nearby stationary post or moving vehicle.
The partial solution I have is to mount the X3/X5 camera to a custom base using the base spare part (from the Inspire 1), connect it to a Zenmuse Z15-BMPCC GCU and connect the GCU to a Lightbridge for control and video transmission. It is partial because 1) the cabling may need modification as I suspect the base has one additional connection at each cable - G6 and G9 in the GCU; 2) I do not know if the GCU can operate or be programmed to operate the OSMO gimbal.
Any suggestions on how to achive this or someting similar with DJI Products?
Thanks
P.S. Sorry for the re-post here. I posted it in the OSMO section but really do not know where it applies better. My excuses if you are reading this for the second time.
