Why the video is shaking???
2743 25 2016-10-7
CROSS OVER
Flight distance : 149938 ft
Lebanon
Hello,
Today, I decided to go outdoor and try out my second Phantom 4 and make sure that everything is fine before I head filming in several areas in the country.
After downloading my short video which I filmed, I found that the picture or the video is shaking.
Do someone experienced this issue before? any idea why the picture is shaking?
It is the first flight outdoor. I had no such problem with my first one which I have crashed 10 days ago. The picture was awsome.
Any settings required maybe?
Thanks
2016-10-7
Geebax
Do you have a video clip you can post here for us to see? If you hover in front of yourself, just above head height, can you see the camera shaking?
2016-10-7
MarcoX5
Flight distance : 1196778 ft
Post the video...
2016-10-7
Hello, please post a video here. And we will help to check it.
2016-10-7
CROSS OVER
Lebanon
Hi all and thank you for the help. I really appreciate it.
Well, I tried to post a part of the video here but didn't succeed for some reason. It's not going through.
I did post the part of the video on you tube then entering the link here under the camera tab but still not okay.
I pasted the link here if you can look it up. If you stair into the video, you will feel like there is an earthquake.
Thank you.
2016-10-8
PartsGuy
Flight distance : 418346 ft
CROSS OVER Posted at 2016-10-8 13:03
Well, I tried to post a part of the vid ...
Is the gimbal set to follow?
2016-10-8
CROSS OVER
Lebanon
PartsGuy Posted at 2016-10-9 04:00
Hi
No the gimbal was not set to follow.
I never tried this option yet.
2016-10-8
CROSS OVER
Lebanon
Also, I want you guys to confirm that you can see what I am seeing in my footage..... Does this what we call shaking ? I never had this issue with my first drone.
I am not really happy with that image shake. It was the first flight for this drone...
2016-10-8
CROSS OVER
Lebanon
Guys do you think something is wrong with the SD card?
The SD card I am using with the new drone is 64 4K  which I have collected from the first crashed drone. Do you think something went wrong with the SD card over the severe crash?
Should I buy another SD card maybe?
2016-10-8
michael_judd
The write speed is whats important on the card. But also after a crash the card could be bad, I have a 64GB - PNY (50MB/s write speed)
2016-10-8
PhanFran
Flight distance : 4804163 ft
Belgium
CROSS OVER Posted at 2016-10-8 22:21
The SD card I am using with the new drone i ...
I don't see too much wrong with this video. There is some movement but that could be from manipulating your joysticks. Try and give us an image that is completely still maybe., without any manual movement of the camera. Also: was there any wind while shooting this ?
2016-10-8
Geebax
CROSS OVER Posted at 2016-10-9 07:21
Do worry about the SD card, it has absolutely nothing to do with the issue. It would seems that the camera is shaking a little. Try flying the aircrtaft just in front of you, just above your head. Look at the camera, is is shaking? Touch the legs of the aircraft, is it vibrating much?
2016-10-8
jwt873
Flight distance : 6754350 ft
I see a definite jitter in the video...   It's not normal in any way.
As a quick guess, one or more of your props might be badly out of balance causing a shake.  Try replace your props with another set.
Also try a craft reset followed by an IMU and Gimbal calibration.
Other than that, you might have to get a repair ticket from DJI
2016-10-8
michael_judd
Geebax Posted at 2016-10-8 18:28
Do worry about the SD card, it has absolutely nothing to do with the issue. It would seems that th ...
If the card was damaged in the prior crash (the op said it was from his previous bird that crashed) it may not be writing the video at the proper speed. So yes, it could be the card. Not saying it is, just that would be the easiest to fix.
2016-10-8
Geebax
michael_judd Posted at 2016-10-9 09:55
If the card was damaged in the prior crash (the op said it was from his previous bird that crashed) ...
If it cannot write at the proper speed it will simply stop writing. An MPEG file cannot write frames at the wrong speed or drop frames.
2016-10-8
DJI-Jamie
Flight distance : 112405 ft
Along with the suggestions in post #13, I would check the dampeners on your gimbal for any tears or if the anti drop pins are not secure.
2016-10-8
Geebax
DJI-Jamie Posted at 2016-10-9 15:13
Along with the suggestions in post #13, I would check the dampeners on your gimbal for any tears or  ...
It is a Phantom 4, it does not have dampeners or anti-drop pins.
2016-10-8
Delta Nine
Check your lens thread, make sure it's not loose.
2016-10-9
CROSS OVER
Lebanon
PhanFran Posted at 2016-10-9 05:13
I don't see too much wrong with this video. There is some movement but that could be from manipulat ...
Hi,
Thank you for your comment.
Wind speed while filming was 12 Km per hour.
I was just lifting slowly the drone with the left joystick. If you look at the tower of the church, you see it shaking like it is going to fall apart. Also, look at the surroundings above the church. The image is not right, shakes can be seen easily.
Thanks.
2016-10-9
CROSS OVER
Lebanon
jwt873@gmail.co Posted at 2016-10-9 06:29
As a quick guess, one or more ...
Hello,
Thx for the help in analyzing the problem.
The props are just new. (First flight), I just removed the plastic and fix them perfectly on the drone with 3 times check on the placement before I started. I didn't make any Gimbal calibration. Should I ?
2016-10-9
CROSS OVER
Lebanon
michael_judd Posted at 2016-10-9 06:55
Hi Micheal,
I tried the same SD card today on another P4 belongs to a friend and the video came out perfect.
So I realized that it is not the SD card.
Thx.
2016-10-9
CROSS OVER
Lebanon
Geebax Posted at 2016-10-9 13:20
No dampeners or anti-drop. It has only the camera hanged on a grey support with nothing to adjust.
2016-10-9
CROSS OVER
Lebanon
Delta Nine Posted at 2016-10-9 17:32
I did and they are fine. Do you mean the black wires? if so, they are fine, nothing is loose.
2016-10-9
Sky Mike
Flight distance : 357503 ft
Few points i have picked up on,
Have you tried to re calibrate it sensors, gimbal, imu and refresh software?
check here post 46
http://forum.dji.com/thread-48578-2-1.html
set up see if helps i find them great
maybe some strong magnetic fields aaround?? maybe the wires and pilon your rite in front of?
2016-10-9
CROSS OVER
Lebanon
Sky Mike Posted at 2016-10-10 00:50
Have you tried to re calibrate it sensors, gimbal, imu and refresh ...
Hi Mike,
I will go through it, hopefully it helps.
thx
2016-10-9
Aardvark
Flight distance : 384432 ft
CROSS OVER Posted at 2016-10-9 18:58
Hi Mike,
The gimbal should be set to 'follow' mode as previously suggested. You said it was not in follow mode, as such the gimbal was effectively locked in position (First Person View mode) and would show any aircraft movement adjusting for wind and turning in the video. In follow mode the gimbal will automatically smooth out any aircraft movement giving you an almost rock steady video.
2016-10-10
