DJI-Jamie
Flight distance : 112405 ft
Just to make sure, is the receiver set to DBus in the Naza Assistant Software? Are you able to confirm that the Assistant recognizes the aircraft by having green/blue LEDs at the bottom corner of the program? If it's connected and the receiver is set to DBus, then you will need to relink the RC to the aircraft. Could you happen to provide a picture of the bottom of the aircraft, so I can verify where the linking button is on your aircraft if need be? |
