fansbf192423
Flight distance : 112822 ft
There is a great video where a guy did a tear down of the Mavic and found that the air intake and fan assembly to keep the drone cool is right behind the camera (this is why you do not fly with the camera cover installed, it will overheat). However, there is not really a way for any debris that gets sucked up into the vent to escape. The conclusion was that if you suck a lot of debris and sand into the cooling vents behind the camera, you will not be able to get it out. This could cause failure over time. They were concluding that you should not take off in grass/sand/gravel without a landing pad. |
