Aircraft Hours
2140 2 2016-10-11
AlaskanTides
Flight distance : 1032293 ft
I am pretty sure that there is not an hour meter in any DJI aircraft.(Other then what is available in DJI GO).... But perhaps someone knows something I do not.
With more commercial Operations it would be handy to note the aircraft hours before and after each flight.
I am currently noting the times in my log book however it would be more thorough to have this information recorded on the craft.
This data would be invaluable to a maintenance program.
DJI GO App helps a bit,  however I am using a lot of 3rd party Apps such as Maps made easy and Autopilot to complete flights. therefore DJI go has no way of keeping track of those additional hours flown with 3rd party software.
There really needs to be a dedicated hour meter onboard the aircraft. it seems this could be accomplished with a firmware update if there is not a way to retrieve this data already available.
Any suggestions?
2016-10-11
gil
Flight distance : 1379308 ft
I am really amazed you haven't heard of Healthydrones.com  Upload the last few flight records from your phone/tablet to check it out. Direction are on the website and it's free for something like the first 50 flights.
2016-10-11
Phantomski
Flight distance : 14869882 ft
the go app has a lot when it comes to replaying your flights, but it does not have much in the way of  querying your flight data.. mind you, dji has all this data if u sync to the cloud - but they never came up with a site to display things, which is weird, because every user that syncs records has a login... (hint, hint DJI). Healthy drones does not reply your logs and flight, but it breaks it up into various stat pages, which is very useful in another way... so between these 2 tools u can do a lot. Then there are additional tools u can use to do data processing on your logs, but really, web based is the best. I have to say i actually paid for healthy drones, after seing how good their work it. They deserve something. If dji had a portal to look at things, and it was not free, if reasonably priced, i'd pay too, but they simply do not...
u can download a healthydrones app for syncing flights from yourdevice used for phantom control.. then u just view things in the web...This is my "summary" screen... really not bad and a good complement to dji go records. Should give yuou a lot of what you probably would like.
2016-10-11
