Quadrocopter
Flight distance : 250125 ft
Doesn't appear to be an issue with your HD settings. With what you have setup in Video Two, you should be recieving some sort of picture from your A7. You seem to be having the same issue my customer did with his same setup, where it looses connection with the copter upon powering up the camera.
Please check this thread:
http://forum.dji.com/thread-65367-1-1.html
We had to roll back the LB and Groundstation (Controller) firmware to fix the problem.
Also, When you power up the A7, are you getting Solid Green lights on the SRW? If so, then you are making a good connection with them and the SRW shouldn't be the issue. However, for diagnostic purposes, always plug the camera straight into the copter rather than through the SRW.
What firmware are you running on the M600 and LB?
