WiPdnMNCLjMr
Flight distance : 171060 ft
The Standard charging hub is the M1CH-S. The Advanced will be called the M1CH-P. I noticed in the manual that both units charge faster using a car charger, probably because a car battery can supply more current than the power supply. Interestingly the Standard hub, using the regular Mavic car charger, can charge 4 batteries in 4 hours while the Advanced hub will be able to charge 4 batteries in 3 hours with the regular Mavic car charger and 2.5 hours with the Phantom car charger. Quite a difference. Seems like if you have the $ it might be worth while to purchase a Phantom car charger and Advanced hub when it's released. |
