Rubber's with glue
1748 11 2016-10-13
Dioden
Sweden
The thing is that the glue stripe that will attaches them got busted when I took the remote apart, now I can’t make them stick where they should and I have been looking at Ebay and DJI, seems like there are nowhere to find? Anyone know?
I have been testing a lot of glued stripes but none of them will stick, bummer. ..
Glued rubbers
Glued rubbers
2016-10-13
Geebax
Get some decent double-sided tape, preferably made by 3M.
2016-10-14
Dioden
Sweden
Geebax Posted at 2016-10-14 10:22
Already done that, it sticks well on the plastic but not on the rubber. ..
2016-10-14
Geebax
Dioden Posted at 2016-10-14 20:43
Fair enough. There is a 3M tape that will stick to rubber, but not generally available to the public. It is used to hold aeroplanes together.
2016-10-14
RicardoGray
Flight distance : 4356421 ft
Geebax Posted at 2016-10-14 17:31
Fair enough. There is a 3M tape that will stick to rubber, but not generally available to the publ ...
Yeah, I have noticed on several remotes that I have taken apart to do antenna mods on that the clear adhesive DJI uses is good stuff. Will be interesting to hear what you guys come up with. I have managed to always salvage it and get them to stick back on, but wondered what I would need to replace it with if they start coming off at some point. I thought the 3M double-sides tape would work too, but guess not. If I come across anything Ill let everyone know, but until then keep us informed if you guys find something. Good luck!
2016-10-14
shakin
Flight distance : 460039 ft
tech7,no more nails or gorilla glue maybe??
2016-10-14
Dioden
Sweden
Geebax Posted at 2016-10-15 00:31
That would really be something, haha. ..
2016-10-16
Dioden
Sweden
RicardoGray Posted at 2016-10-15 00:37
Yeah, I have noticed on several remotes that I have taken apart to do antenna mods on that the cle ...
Well, I found a way to do it and it seems like it works. I took my glue gun; it’s a thing that warms up a glues tick so it melts and I glued it together, still holding.
2016-10-16
afiend69
Flight distance : 626647 ft
good idea, hope it holds.  if not, open the remote and mark holes in the rubber where the screws are and drill holes out of the rubber - then glue it permanently - that's what I will do.
2016-10-17
rustymichaud
Contact cement both sides,clean before it won't come off
2016-10-17
04red6
Flight distance : 5484997 ft
Use the two sided tape that is used to hold screens to phones and tablets. I have some and it works.
http://www.ebay.com/itm/3-SHEETS-3M-467MP-DOUBLE-SIDED-ADHESIVE-TAPE-LCD-DIGITIZER-GUITAR-PICKGUARDS-LCD-/182280865526?hash=item2a70c946f6:g:TbEAAOSw65FXsMBp
2016-10-17
Dioden
Sweden
04red6 Posted at 2016-10-18 05:29
Use the two sided tape that is used to hold screens to phones and tablets. I have some and it works. ...
I know that it exists, but haven’t seen it myself. But it could work, no doubt about it. I’m not working with that kind of stuff anymore, so I have to use what I have. So far, it sticks.
2016-10-18
