Donnie
Flight distance : 3636782 ft
Ok , couple questions . Is that Samsung an approved device ? does it work just fine on the master if you switched it around ?
Can you take a screen shot of BOTH" about "pages to compare the FW versions on both ?
When you updated are you sure that both RC transmitters went to 1.7 ? sometimes they are on different levels of update and might not havbe both gone to 1.7 . THEY BOTH MUST MATCH EACH-OTHER
Do you have a page on the Remote control Settings page that has Master Slave and off like picture below ? It should have this on there ( I have an I pad and it shows up on remote control settings . EDIT ::::This is android so I think it is NORMAL .
Make sure that the RC Stick settings on both the Master and Slave are matched. I believe they default to mode 2 but make sure they match . ( Make sure systems are on to verify )
ALSO CHECK IF BOTH GO APPS ARE ON IMPERIAL OR METRIC under general settings .
I would delete and re install the go app on the RC slave , it only takes a minute and might solve the problem as well.
Also when you made the slave remote the master , You MUST re link it to make it work , this is done by pressing the red button on the aircraft inside the nose , it is just behind the right front silver nose cone screw, might need flashlight, you may want to try that again if nothing works to make sure that RC does inded work . You must start the re link from the Remote control setttings and then it is a timed procedure to press the red link button .
Dont do this till we see what versions are on the GO app" about" page.
let me know
donnie
