AGRAS MG-1 Liquid Indicator Problem
Sapibetina
Indonesia
Hi,
We encountered a problem with the indicator fluid tank. This problem occurs when AGRAS operates in smart mode, drones detect fluid in the tank runs out and stopped spraying then hover up, while the tank is filled with plenty of fluids. We try to normalize the indicator, switch back to manual mode and press the spray button until the tank indicator turns green. It works, but when switch to the smart mode, it happens again. Is there a problem with the pump or something else?
2016-10-16
fanse690b572
Chile
i have the same problem how did you fix the problem
2017-12-26
Ueli
Flight distance : 1696079 ft
Switzerland
This happens when the pump has too less resistance. Causes can be: leak in pipe, nozzles too big, pump defect.
2017-12-31
djiuser_18COrX7qQ4T6
Hi،good time
Can the pump open and clean up? Or have you changed the pump?
2018-6-4
Ueli Posted at 2017-12-31 01:30
Hi good time
about problem of pump of agras mg1:
2018-6-4
MOZZIES
I hav the same issue and it isn't getting resolved.  I can't even get the thing to take off
2018-10-21
