DJI-Jamie
Flight distance : 112405 ft
From what I was able to acquire, there is only one type of Manfrotto backpack that is sold on the DJI Website, and it is advertised to work with the Phantom 2, Phantom 3 and Phantom 4 models. The backpack is made to fit units snugly, so as to not tostle around too much while in use. When you are zipping up the main compartment, you cannot let it cave in, or else it will feel like it's struggling to close. It's fare more square in nature that one realizes. It's not as straight forward as the older units, but you can fit about 6-7 batteries inside the backpack depending on whether you leave a battery inside the unit. I have some pictures of where you would store them:
Yes the strap will work with the P4's gimbal clamp, but this is how you would essentially strap it in. Regarding a partial refund for just the backpack, it's not able to be done when it's in a bundle, it would require for everything to be sent in and purchasing a different bundle that would not have a back pack. If you're outside of the refund policy at this point, which is 7 calendar days from delivery, I don't belive a refund would be possible. If you're still corresponding with onlinesales, they would be the only ones who would potentially be able to make an exception.
