Sean-newbie
Flight distance : 15997 ft
If your drone is linking with the controller then, with the drone off, switch the controller on and connect it to your phone or tablet. Start the Go app for your drone and have a look in the controller calibration menu, waggle the joysticks, does the image on your screen change in accordance with the movements of the joys stick ( lines of blue dots on mine which lengthen or shorten)?
Slowly move the joysticks to the motor start postions, again, does the image on your screen change in accordance with the movements of the joys stick?
I have a controller with which the output, shown on my screen, for the RH joystick SUDDENLY switches from 100% back to 100% forward. This happens once the 100% back reading has been reached and the joystick is moved beyond that point towards the "back" limit of its travel.
I can not, via the joysticks, start the motors of a linked drone with this controller BUT I can start those motors via the launch button on the screen of my phone or tablet. The drone then flies perfectly PROVIDING I do not exceed the 100% back position.
I suspect the problem lies in a sensor/potentiometer on the end of the forward/back pivot. |
