DJI-Jamie
Flight distance : 112405 ft
If you could answer Natalia's questions, that would be appreciated. Also, your aircraft is up to date as well, correct? Prior to performing a RC downgrade, could you happen to try the following button combinations to ensure that the connection on both the aircraft and RC are refreshed? First, please reset the RC using the following combination:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the RC (with the above buttons still being held) and the aircraft and relink the two.
I would then recommend a manual relink using the following combination:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD.
*Let go all fingers, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
Please give those a try first. If it persists, please try a RC downgrade as Natalia suggested by holding the menu button on the top right corner of the Equipment page for 3-5 seconds. You will then see the options for downgrading the RC. Please make sure that the aircraft is off when you attempt the downgrade.
