Ronin MX Control Smoothing don't work on pan
1744 2 2016-10-18
daniel
Sweden
Hi there. I am experiencing a problem with the Control smoothing option on the pan axis. When I use control smoothing on the tilted axis I am able to get a really smooth stop. But when I use the control smoothing options on the plan taxes it always makes a hard stop. If I increase the smoothening value is slows down at a slower pace. But when it comes to a stop, the stop is still hard. I do not experience the same problem with a tillt axis tho.
I also have the Ronin set up with the Matrice 600 and I experiences the same problem there.
I really appreciate if someone can help me.
//Daniel
2016-10-18
daniel
Sweden
The problem got solved when I re-calibrated the rolling and put everything by default. Once I had done that I could enter my settings and everything works just fine.
2016-10-19
DJI-Jamie
Flight distance : 112405 ft
daniel@driley.s Posted at 2016-10-20 08:54
The problem got solved when I re-calibrated the rolling and put everything by default. Once I had do ...
Great to hear you got yourself up and running.
2016-10-20
