Phantomski
Flight distance : 14869882 ft
i do not see how modifying the radio is not violating the fcc regs as well.. after all the whole point of an amplifier is to increase the signal sent by the radio, right? I wonder if those extended antenna amps have FCC stickers, and if so, how the heck did they do that? And yes, I can see the point of the original OP - u amp the signal on the radio, but at some point the link failure will probably not be the tx signal being readable by the drone, but the drone's reply not reaching the TX.. so people going 5mi +, that shows that the signal coming back from the drone, is actually stronger than the stock signal sent to the drone, if there was no amplifier on the transmitter... Interesting.
