FPV mode question
802 7 2016-10-19
Phan-TOM
Flight distance : 61184 ft
Why does the Phantom 4 gimbal exaggerate roll in FPV mode?? This is so annoying!! Is there a way to turn it of or set it so the gimbal just stays in a fixed position?
2016-10-19
Aardvark
Flight distance : 384432 ft
Go into gimbal settings menu and change from 'FPV' to 'Follow'.
The gimbal will then stay level as the aircraft turns, or gets buffeted by wind etc.
2016-10-19
dirtdroner
Flight distance : 3633799 ft
Yeah, having it just match the craft would be great. 'Follow' eliminates it totally and 'FPV' exaggerates it to beyond use. I get what they're trying to do by artificially tilting the camera because the craft turns without tilting unless you use both sticks. They just went way overboard. One feature I really liked on my Bebop 2 before I totaled it was that they gave you the option to combine yaw and roll with a single stick. Made it like flying a plane and made really great video. I guess DJI thinks of it more as a floating camera than an flying aircraft. Maybe they could at least add it to Sport mode.
2016-10-19
Cetaman
Flight distance : 2528264 ft
Aloha TOM,
     Aardvark has the quick fix and that can be enough for some.  But there are settings that allow you to use FPV smoothly in a non-exaggerated way for cool videos like DirtDroner notes.
     Right now you will have to figure it out for your selves.  I have just seen it done on this Forum and have not flown since then, but I cannot wait to try.  When I figure it out I will post it.
     Hope this helps!
Aloha and Drone On!
2016-10-20
Cetaman
dirtdroner Posted at 2016-10-19 15:07
Yeah, having it just match the craft would be great. 'Follow' eliminates it totally and 'FPV' exagge ...
Aloha dirtdroner,
     There are settings that allow you to use FPV smoothly in a non-exaggerated way for cool videos like you noted.  Right now you will have to figure it out for yourself.  I have just seen it done on this forum and have not flown since then, but I cannot wait to try.  When I figure it out I will post it.
     Hope this helps!
Aloha and Drone On!
2016-10-20
dirtdroner
Sounds like the hot ticket. If I knew how to search these boards I'd look up Aardvark to read the posts.
2016-10-20
Phan-TOM
Thanks for the replies guys.. Ill check out FPV "follow" -  on another note, "dirtdroner" I can't tell if you're being serious or sarcastic.. lol!
2016-11-3
dirtdroner
Though I have certainly had some fun with tongue in cheek before (crappy app), this time it's real. I'd love to be able to combine a turn and roll to make it seem like flying a plane, the manufactured FPV mode from DJI stinks, and I don't know how to search the boards by author.
2016-11-4
