Phantomski
Flight distance : 14869882 ft
Depending on the wind, your feet will show up sometimes.. when your left leg shows, try going and tunring to the left then to the right, see if that helps.
Are you planning to film or take photos?
If you take photos, be in manual mode and play with flying backwards/forward and/or sideways slowly, see if that helps to get get a good shot with nothing in view...
When i shoot the sky i learned to fly back to raise the front props, so they are not in the shot....
If you do a long exposure, naturally u can only be moving slowly and steadily, and maybe u just cannot. Either way, u can crop pictures as well as video, u just need an editor that can do it....Also, trey flying with full moon, and u can even try at dusk.. many light come on already, but yet it's not completely dark.. if u r an early bird, morning is an option too - just be ware of morning fog/dew and temperatures.. between mositure and cold, may be a problem....
Or, just hire a helicopter with a wide spotloght ;)
Good luck...
