Zenmuse H3-3D wiith GoPro Hero 4
1856 4 2014-10-1
uncle.scrooch
South Africa
Hi Guys
Does anyone know if the current Zenmuse H3-3D will be able to support the GoPro Hero 4..?
I'm thinking of buying the gimble but I don't want to get it only to find out I can't use a GP Hero 4 with it. Thanks in advance
2014-10-1
T J Gilbert
Flight distance : 74659 ft
Your answer is a conditional yes.
There is a gimbal thread...
Several posts concerning your question are already over there...
2014-10-1
uncle.scrooch
South Africa
Thanks
2014-11-27
nickaizzy
HOWEVER, there is an issue where the gimble hits the new settings button on the side of the GoPro 4.  It's really annoying because it can mess up the settings of the gopro a bit, including forever having your wi-fi on whenever you fit your GoPro into your gimble.
I have found a work around in which I stick a penny (or something of equal thickness) into the lower left corner of the gimble before I stick my GoPro 4 in it.  That way it pops the GoPro out a bit and gives the new settings button on the side a bit of space so the gimble does not constantly press it.
2014-11-27
away-point
Between my own experience and what I've read, I'd say there is a 75% chance it will work without issue.
You may have an issue with the side button as mentioned above, and/or might need to tweak the balancing.
That said, I have a hero4 that has worked without either problem.
2014-11-27
