How protect P4 battery life when no using Phantom 4
1898 11 2016-10-21
coolure
Flight distance : 15049 ft
United Arab Emirates
Hi DJI
How we protect PHantom 4 battery when bird no using for a long time
please advice
2016-10-21
labroides
Flight distance : 9991457 ft
The battery will self discharge to storage level.
Make sure you recharge it before flying
2016-10-21
DJI Natalia
Flight distance : 318 ft
Hi Coolure, please fully-discharge it then fully-charge it every 3 months, battery life maybe reduced if not used for a long time.
To protect the battery, please check the details here: https://dl.djicdn.com/downloads/ ... y_Guidelines_en.pdf
And hope this tutorial helps:
2016-10-21
coolure
Hi Nath..
can u tell me how we fully discharge!
2016-10-21
coolure
you mean for the 0% right!
2016-10-21
DJI Natalia
coolure Posted at 2016-10-21 20:10
Correct, 0%, you could do it as the following instruction:
2016-10-22
coolure
Thaks Mindi
2016-10-24
Phantomski
Flight distance : 14869882 ft
do u really want to discharge it that low? Is not 10-8% good enough for even extended storage? Too low, and don;t yopu risk it actually going lower than healthy for the battery?
2016-10-24
Vincent D
Flight distance : 622841 ft
Simply set it up in the to discharge after a few days.
2016-10-25
Aardvark
Flight distance : 384432 ft
I wouldn't discharge to 0, you will likely damage the battery.
As said the battery will self discharge to 50% for storage.
2016-10-25
Nigel_
Flight distance : 388642 ft
Aardvark Posted at 2016-10-25 14:48
As said the battery will self disc ...
The instruction was to fully discharge it and then fully recharge it once every 3 months, just to give it some exercise, you then store it fully charged and it will self-discharge to 50% and will probably loose another 1-3% over the following 3 months before you give it some more exercise.
If you are using it normally, and never take it below eg 40%,  it may still be good for the battery to give it a full discharge once every 3 months.
2016-10-25
Aardvark
Nigel_ Posted at 2016-10-25 15:07
The instruction was to fully discharge it and then fully recharge it once every 3 months, just to  ...
Lipos can be over discharged which will damage them, the instruction refers to discharging to 8% (not 0%), and the instructional video (at about 2:52) suggests that over discharge may make the battery unusable.
2016-10-25
