jaredraab
I've recently purchased a Ronin M, to use with my A7s ii. It is being used on a documentary shoot, so long days and small two-man crew.
I'll be wiring my A7s ii to run off the p-tap in the sled of the Ronin with an adapter. I ALSO want to run my Small HD monitor off the Ronin battery if possible. The idea here is to minimize weight and inconvenience by running everything off the Ronin battery. So obviously a bigger battery would be wise.
If I purchase the larger Ronin Intelligent Battery 4350mAh (MFR # CP.ZM.000367) along with the Ronin Power Distributor (MFR # CP.ZM.000301), will it all work smoothly? So basically three questions:
A) Will it run my Ronin M from that larger battery?
B) Will the distributor work to simultaneously power the monitor (through an adapter obviously) AND the Ronin.
C) Which charger should I buy for the later battery? Can it use the same charger that came with the system for the two 1580mAh intelligent batteries?
Thanks very much!
Jared
