Switching to A2 thoughts
993 3 2016-10-24
Rinzler
So I have been toying around with the idea of selling my Inspire and buying a A2 and just building one out with a light bridge setup. I love my Inspire but the flight time really sucks on it. 12-15mins sucks when sometimes I just wanna fly around or go long distance. I was thinking about a Tarot x6 frame with the A2 and lightbridge 2 setup. Load it with a 10k to 22k lipo for long flight time. I seen some where I could use the x3 with that flight controler but cant find the bracket now. Anyways, thoughts?
2016-10-24
DJI-Jamie
Flight distance : 112405 ft
If you want to use the X3, then you would need to the A3 flight controller in order to use the M600 X Mount kit. As long as the unit is not heavy, you should be able to get better flight time. If you like DIY projects in general, then you should enjoy building it. Keep in mind that a DIY craft can get expensive really quickly if you don't already have most of the components.
2016-10-25
Rinzler
DJI-Jamie Posted at 2016-10-25 11:58
If you want to use the X3, then you would need to the A3 flight controller in order to use the M600  ...
Ah so the A3 is needed. I have most of the parts like esc and motors etc. Thanks Jamie
2016-10-25
DJI-Jamie
Rinzler Posted at 2016-10-26 04:08
No problem.
Good luck with your rig!
2016-10-25
