Antenna for Phantom 3 standard
1451 5 2016-10-24
remi_rl
Hi guys
I've broken the antenna  of the RC ... (2,4 ghz)
I'am looking for a solution.
I will install : http://www.wifi-highpower.com/19 ... vers-ufl-10-cm.html
And put a new antenna.
Do you know if it's a 3db or 5 db ?    Thanks !!
2016-10-24
billwish76
Flight distance : 175495 ft
So which one did you break?  because the 2.4 are the Wi-Fi antennas on the inside 5.8 gigahertz is the main Transmission that its external.. I haven't seen any for sale and less someone did a mod and still has theirs get a DBS mod they work pretty well and you'll get the Wi-Fi with the transmitter antenna in one unit snaps on easy and just comes with everything you need
2016-10-24
DJI Natalia
Flight distance : 318 ft
Just as billwish76 mentioned, it would be best to send it in and get the antenna repaired by DJI authorized engineers.
You could contact our tech support at support.eu@dji.com for further help, or you could check the local repair center on this website: http://www.dji.com/service/repair/centers
2016-10-24
remi_rl
billwish76 Posted at 2016-10-25 01:15
So which one did you break?  because the 2.4 are the Wi-Fi antennas on the inside 5.8 gigahertz is t ...
My broken antenna is the main, the external.
I just want to repar it with another one . i don't want to install a long range.
What are the solutions ?  just want an equivalent to origin
http://gridconnect.com/industria ... antenna-cables.html
2016-10-24
remi_rl
I've repaired it with a wifi antenna and a plug ;) it's perfect
2016-10-25
billwish76
awesome great
2016-10-31
