Gimbal Roll
1199 4 2015-2-3
Nes
So, I did a search in the forum prior to positing this, and all I found was someone with the same issue asking if anyone else is experiencing the same. No one has repsonded, so I am trying a new one here with images...
Noticing that the Gimbal ROLL is off quite a bit upon start up. Now, I can run it through a Gimbal Auto Calibration and it will fine tune the balance and level it, but once it goes through the second half of the calibration (rotating) it goes back to being off.
Anyone having/had this issue, was there a remedy for it?
See images attached...
Gimbal Roll
Gimbal Roll
Gimbal Roll2
Gimbal Roll2
2015-2-3
Heliflo
Flight distance : 8885013 ft
Switzerland
already tried imu and compass alibration?
THis normally sorts such issues out...
Huge temperature changes also could cause such issues...
2015-2-3
FrostyThe2nd
Happening to me too.  I contacted DJI and after calibrations on various surfaces, I was given the option to send the entire craft back to DJI for repair.  I'm debating on doing this as it's an inconvenience in having to secure and send the bird back.  Plus fees.  Then it's a waiting game all over again.  Worst than for the preorders because at least you can cancel and get your money back with preorders.  I'm going to explore other ways to resolve this.
2015-2-3
Nes
FrostyThe2nd Posted at 2015-2-4 12:03
Happening to me too.  I contacted DJI and after calibrations on various surfaces, I was given the op ...
Ok... I spoke with tech support in L.A. and they said to send the copter in to them for further evaluation and that turn around time was 3 weeks. I am not one to calibrate the IMU on every flight as I have not found the need. I do calibrate the compass prior to flight, especially when flying in a new area.
Now tonight I calibrated the  IMU and the compass and it was the same. I decided to do it a second time, and now everything seems to be back in working order.
2015-2-3
kalle This user has been deleted
2016-1-19
