pinpointmapping
Flight distance : 5345105 ft
I posted this on the duplicate question, but figured it never hurts to repeat it...
You may be able to use the Video stream with some software from ESRI called FMV (Full Motion Video)
http://www.esri.com/products/arc ... y/full-motion-video
Or you could take multiple still images (you could do frame grabs from the Video, but even 4k video isn't as good as a 12mp still) and use either Drone2Map (another ESRI product) or just use Pix4D to process the images (the concept is called Structure from Motion) and create a high resolution 3d model that would allow for accurate measurements.... Let me know if you need more info to get started. It helps if you have an understanding of GIS.... |
